TPS code draw timing?
may not change timing but may produce a lean condition (stumbling/hesitation), because the computer does not recieve the right signal telling it to add fuel as the throttle opens. you should eventually recieve an o2 sensor code if i am correct. also the tps is the only link from you to the engine.
