Need LS-VTEC cam help
Old Dec 8, 2006 | 10:07 AM
the4g4d's Avatar
Default Need LS-VTEC cam help
So, building an LS-VTEC for the EF. Wondering if anyone knew the maximum lift possible in an LS. right now the set up is as follows-
stock LS bottum end
stock GSR head gasket
RLZ stage 3 cams(howard said he'd never used these on stock pistons) measuring-
in 253@50 .513 lift
ex 252@50 .480 lift
obviously with tit. springs and retainers.
Will these work?
Old Dec 13, 2006 | 07:28 PM
spooledex's Avatar
Default Re: Need LS-VTEC cam help (the4g4d)
your not going to have hardly any compression to push those cams.
Old Dec 15, 2006 | 12:14 AM
ekgcool's Avatar
Default Re: Need LS-VTEC cam help (spooledex)
True. 9.XX:1 compression and big cams = waste of time and money. If anything use Type R cams.
negusjuda
Apr 11, 2011 06:43 PM
supratin
Aug 4, 2007 03:30 PM
revteglsv
Oct 11, 2005 06:28 PM
xDicktonesx
Jul 28, 2005 12:59 AM
infamousALLMTR
Sep 15, 2002 08:12 AM
