TPS
im throwing a tps code on my ls/vtec swap when i use a pr4 ecu (forced to cuz the ecu i was planning on using is junk) and it idles around 1500. I searched and read a few posts about calibrating the tps and my question is, if the voltage is off, does it throw a code? With my junk ecu (p08) the motor idles fine. ( the reason the p08 is junk is cuz you cant pull codes from it and its forever stuck in limp mode.) Thanks in advance for the help.
-KangaRod-
Jun 22, 2005 05:45 AM
