Torque Specs Needed for Spring/Shock Install on a 99Si. Can you help?
Old May 21, 2003 | 06:54 PM
ModAddict's Avatar
Default Torque Specs Needed for Spring/Shock Install on a 99Si. Can you help?
I thought the specs would come with the instructions for the Comptech springs and Tokico Iluminas. Guess not. Can you help? they are going on a 99Si. Any other tips on the install? Thanks
Old May 21, 2003 | 07:10 PM
4DeepCivic's Avatar
Default Re: Torque Specs Needed for Spring/Shock Install on a 99Si. Can you help? (ModAddict)
I can't give you a torque spec, unless you tell me exactly which nut or bolt.
Modified by 4DeepCivic at 1:48 AM 5/22/2003
Old May 22, 2003 | 07:34 PM
ModAddict's Avatar
Default Re: Torque Specs Needed for Spring/Shock Install on a 99Si. Can you help? (4DeepCivic)
Got em, thanks.
Old May 23, 2003 | 12:41 AM
Stripped Honda's Avatar
99-0104
just make them tight i never need torque specs .... just looking at the nut or bolt you can tell how tight it should be ... about the only time i break out my torque wrench is when i am tightening head bolts and thats it ....
onwisconsin81
Apr 5, 2010 01:25 AM
truevietluv636
Jan 25, 2006 01:34 PM
acatak
Apr 17, 2003 07:30 PM
2000Accord5sp
Dec 10, 2002 07:40 AM
