tools needed for extended wheel studs?
Old Feb 23, 2004 | 03:29 AM
vtekthis's Avatar
Default tools needed for extended wheel studs?
can somebody tell me what tools im going to need to tackle my next job? im doing extended wheel studs on my 99 civc ex coupe and just wanted to know before i start. i heard you need a press? is this true? also please tell me if this if more of a DIY job or should i wait till i have a good amount of time so i can get to a press? any help?
thanks
Old Feb 23, 2004 | 03:56 AM
vtekthis's Avatar
Default Re: tools needed for extended wheel studs? (vtekthis)
anyone know???
Old Feb 23, 2004 | 06:34 AM
doublejz's Avatar
you will need a press. your gonna have to press the hub apart to remove the wheel studs. Sometimes you even need the press to push the studs out, or you can beat them To put them in, I usually just put the studs in, oil them a little, put some washers on it and crank them tight with a lug nut to pull them the whole way. Then put the hub part together
Old Feb 23, 2004 | 07:14 AM
vtekthis's Avatar
ok, thanks, so its not a job to do without a little time and a press.
Old Feb 23, 2004 | 07:42 AM
dfoxengr's Avatar
Default Re: (vtekthis)
you dont HAVE to havea press. use a sledge, and then bring the new ones on with lug nuts and an impact
Old Feb 23, 2004 | 01:07 PM
doublejz's Avatar
Default Re: (hybridvteceg)
i dunno about you, but last time i changed mine, i needed to take the hub apart which i needed a press to do.
Old Feb 23, 2004 | 01:25 PM
slixxracing's Avatar
Default Re: (doublejz)
you dont necessarily need a press to get the job done, but it will make it hell of alot easier w/ one. by the time you're hammering away the hub to knock it off you'll be saving yourself alot of time just having it pressed out. took me about 1hr before hammering my hub in. once i got it done, it was all screwed up...had to buy new ones and replace them again. but the second time, i paid a shop to press it in for me.
Old Feb 23, 2004 | 03:12 PM
RCautoworks's Avatar
Default Re: (slixxracing)
You do not need a press, you need air tools and a slide hammer.
Old Feb 23, 2004 | 06:46 PM
fullracegsr's Avatar
Default Re: (90blackcrx)
all you really need is a slide hammer... air tools help but are not a must...
Old Feb 23, 2004 | 08:08 PM
slammed_93_hatch's Avatar
Default Re: (fullracegsr)
saying you don't need a press is like saying
you don't need a hoist to do a swap
Old Feb 23, 2004 | 08:09 PM
dfoxengr's Avatar
Default Re: (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">saying you don't need a press is like saying
you don't need a hoist to do a swap</TD></TR></TABLE>
you dont need a hoist to do a swap.
think lift the car over the engine. lol. bad simile.
Old Feb 23, 2004 | 08:19 PM
wow you obviously didn't get my post.
Old Feb 23, 2004 | 08:21 PM
dfoxengr's Avatar
i thought u meant you have to have a press. be clearer, lol
Old Feb 24, 2004 | 02:29 AM
i was being sarcastic.
just use the press itll be alot easier
Old Mar 15, 2004 | 10:53 AM
dumppp gook's Avatar
what is the press called? i need it... i dont know how to get my damn studs out cuz thers something blocking it from the back....what do i doooooo!!!!
Old Mar 15, 2004 | 10:54 AM
dfoxengr's Avatar
Default Re: (integrallmotor)
its a shop press. but you can implement a slide ammer, or an air impact gun
743power
182
May 19, 2017 07:30 AM
TSAngry
Nov 8, 2007 01:57 PM
LudeyKrus
Jul 26, 2004 10:42 AM
deez nuts
Jun 10, 2004 10:39 PM
dynamo
Sep 20, 2002 11:37 AM
