too rich in only one cylinder, help
Old Aug 31, 2003 | 03:01 PM
g5r's Avatar
g5r
Default too rich in only one cylinder, help
im running too rich in only one cylinder, the rest is fine when i look at the spark plugs. the cylinder is number 4, what can cause this? what can i look into?
Old Aug 31, 2003 | 03:02 PM
Defender's Avatar
Default Re: too rich in only one cylinder, help (g5r)
check the injector, probably stuck open/closing slow
Old Aug 31, 2003 | 04:49 PM
SOFLSOL's Avatar
Default Re: too rich in only one cylinder, help (Defender)
How can you check your injectors?
Old Aug 31, 2003 | 04:50 PM
blah13's Avatar
Default Re: too rich in only one cylinder, help (SOFLSOL)
You can either have it rebuilt or get a new one. Personally I'd get them all balanced or replace them all at the same time.
Old Aug 31, 2003 | 08:11 PM
Runnerdown's Avatar
Take the fuel rail out and make sure the injectors stay in the rail. Then turn the key on, the fuel pump will turn on to prime the system and will pressurize the rail/injectors. If the injector leaks gas, it should be replaced.
Old Aug 31, 2003 | 08:54 PM
fox297's Avatar
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">Take the fuel rail out and make sure the injectors stay in the rail. Then turn the key on, the fuel pump will turn on to prime the system and will pressurize the rail/injectors. If the injector leaks gas, it should be replaced.</TD></TR></TABLE>
Don't the injectors come out when you take the fuel rail out.
I heard some people use a battery and hook up to the injector for it to open then use presurised air to clean out the internal. I want to clean my injectors also but I'm not sure if this is safe.
Old Sep 1, 2003 | 12:10 AM
T4eg's Avatar
Default Re: too rich in only one cylinder, help (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">You can either have it rebuilt or get a new one. Personally I'd get them all balanced or replace them all at the same time.</TD></TR></TABLE>
Old Sep 1, 2003 | 07:17 AM
g5r's Avatar
g5r
where can i take them to get it balance?
Old Sep 1, 2003 | 07:19 AM
Runnerdown's Avatar
Default Re: (fox297)
The o-rings where the injector goes into the rail will usually hold them in. Sometimes though the grommet that the injectors seats into will want to hold it. A long as you take them out carefully you should be ok. I have done this plenty of times.
Old Sep 1, 2003 | 05:18 PM
g5r's Avatar
g5r
would having one cylinder running rich, does this turn up an cel for misfiring?
Old Sep 1, 2003 | 05:23 PM
Runnerdown's Avatar
Default Re: (g5r)
If its OBD2 its gonna have a CEL.
Old Sep 1, 2003 | 07:52 PM
sleepinonacreeper's Avatar
check your cap, rotor, wires, and plugs too. also check compression to see if it is lower in that cylinder. shame on everyone for not mentioning this
Old Sep 3, 2003 | 09:28 AM
g5r's Avatar
g5r
Default Re: (sleepinonacreeper)
my compression is 230 across. i got new wires also.
Old Sep 4, 2003 | 06:04 AM
g5r's Avatar
g5r
ttt
blu3fan
Nov 16, 2012 05:05 PM
90civSi
Jun 22, 2006 12:23 PM
locoSIR20
Feb 9, 2005 04:09 PM
jthm
Jul 9, 2004 06:13 AM
baonest
Aug 5, 2001 02:51 PM
