Timing problems
Old Jun 14, 2010 | 01:42 PM
boostedteg1203's Avatar
Default Timing problems
I'm having problems setting the timing on my Integra. When I use a timing light to adjust the distibutor, I can't rotate the dizzy far enough back to get the timing at 16 degrees on the crank markings. It's actually not even close! The crank and cams are set correctly and the jumper is connected while I adjust the dizzy. Also base timing is set to 16 degrees in my S300. I feel that this is killing my power! I only made 360whp on 20psi with a T60-1 turbo. Anyone know how I can fix this?
Old Jun 14, 2010 | 03:59 PM
bryse68's Avatar
Default Re: Timing problems
Check ur crank pulley. it probably spun. this happened to me this past week. i couldnt adjust the timing and the outer ring on the crank pulley spun on the rubber part.
Old Jun 14, 2010 | 04:37 PM
What rubber part are you talking about? Isn't the crank pulley one solid piece?
Old Jun 15, 2010 | 03:11 PM
bryse68's Avatar
nope. there is a rubber that seperate the power steering pulley and alternator/ac pulleys. unless you have an aftermarket pulley
Old Jun 15, 2010 | 03:16 PM
delsolproblems's Avatar
Some are. Some have the rubber ring that Bryse is referring to. The ones with the rubber most often go bad when someone uses a torch to heat and loosen the pulley bolt. It ends up melting the rubber. Did this myself once, I'm sorry to say. Aside from checking the pulley for damage, you can make sure of its position by loosening the bolt, line up the TDC mark on the pulley with the notch on the timing cover, remove the pulley and then see if the crank timing gear is pointed at the TDC notch on the oil pump housing.
MenaceL.A.671
Sep 13, 2005 04:10 PM
iperez
Jun 24, 2004 06:58 AM
civbeater90
Nov 16, 2002 12:46 PM
89JDMcrx
Sep 25, 2002 05:22 PM
Nick248
Sep 9, 2002 09:59 PM
