timing On JDM ITR 99
Old Dec 6, 2006 | 05:05 PM
Rishiras's Avatar
Default timing On JDM ITR 99
Guys,
I got my JdM ITR 99 from Japan, when cheking the timing it was between 14-15 Degrees.
I run on 103 Octane VP Racing Fuel on 18 degrees , 2 degree advance above 16 stock.
Should this be ok for the type of fuel using.
Pump gas we have 95< but its actually 92 octane> I will then use 16 Degrees stock.
Any recommendations?
R
Old Dec 6, 2006 | 06:03 PM
Downey's Avatar
Default Re: timing On JDM ITR 99 (Rishiras)
i run 18 degrees on 91. 18 will be fine on 103.
Old Dec 10, 2006 | 02:38 PM
Rishiras's Avatar
Default Re: timing On JDM ITR 99 (Downey)
Ok , I am thinking of not using 103 everty time, since expensive.
Can I use 95 Pumpgas which is around 93 according to most guys in Curacao here on this JDM spec R 99 11.1 CR B18C?
Is this better to use 16 stock timing or ok on 18 Degr advance for daily driven!
What is most used to obtain best 1/4 mile results and still be safe.!!
Modified by Rishiras at 7:20 PM 12/10/2006
CivicHP
Oct 25, 2005 09:15 PM
jbell
Jul 11, 2004 01:14 PM
smkngsr
Jun 2, 2004 09:42 AM
yaya
Mar 18, 2004 10:08 PM
Ladies Man
Jun 15, 2001 06:58 PM
