Timing Belt & Water Pump
Old Jun 10, 2002 | 11:52 AM
SikofFalln's Avatar
Default Timing Belt & Water Pump
I am changing the timing belt and water pump on my B18A today and I was curious if anyone had any pointers on how to do this? I know I need to put the #1 cylinder at TDC before I remove the belt and loosing the tensioner, anything else that I should be aware of? Thanks...
Old Jun 10, 2002 | 04:52 PM
minime's Avatar
Default Re: Timing Belt & Water Pump (BseriesPWR)
there kinda tricky if youve never done one b4. get yourself a manual, almost any manual that has that motor in it will show you the timing marks and procedure to do it correctly. double check your marks when youve got the belt back on and make sure it tight, but not to tight. good luck
Joe Sobeski
Acura TL, RL & ZDX
Sep 10, 2018 08:51 AM
Ennis555
Apr 11, 2017 09:21 PM
MikesEJ1
15
Oct 1, 2013 09:22 AM
NFrank89
Oct 19, 2010 06:59 AM
zracer240
Aug 1, 2005 10:07 AM
