05 TL under 90K, how long til I need to do timing belt?
i bought the car with 76K knowing I should do the timing belt but it’s been running good and I’ve already done the water pump tensioner n belt kit. Any advice? Thanks, Joe
Re: 05 TL under 90K, how long til I need to do timing belt?
Typically what gets brought up is 105k miles or 7 years whichever comes first, most of what I have seen is the 105k mile part. This is for standard operations, there is also extreme conditions that can make the service intervals more frequent. I believe that manual that comes with the car list it as well.
As of the 3G TL (2004-2008) and 7G V6 Accords, Honda dropped the 7-year requirement; the only requirement in the manual or in your OBC is 105,000 miles.
What do you mean by you've "already done the water pump tensioner n belt kit"? If you did the water pump then you had to take the timing belt off.
car5car
07-09-2017 05:41 AM
