timing belt effed up............
Old Sep 24, 2006 | 11:32 AM
MR_FIX_IT's Avatar
Default timing belt effed up............
my buddy stripped out his timing belt on his 96 LS integra. I tore it apart, put everything back in time and put a new belt on. It starts up fine now but makes a noise, almost a "Grinding" sound and the check engine light is on. I replaced the timing belt on mine( 91 LS integra) and never had these problems..............Any ideas as to why the light is on and why it sounds like a coffe grinder.
Old Sep 24, 2006 | 12:37 PM
so lazy's Avatar
Default Re: timing belt effed up............ (OldSkool_DA9)
lets see... here... 91 and 96 is way diff due to obd1 obd2 and its crank sensor is at the bottom where the crank gear is and yours is not... might want to check that engine light and come back on here and tell us what that CEL is so we can go from there..
Old Sep 29, 2006 | 10:44 PM
MR_FIX_IT's Avatar
he took his car to autozone and had the code checked. His MAP Sensor is bad, that would explain why it wouldnt start pulling till 4 grand.
Old Sep 30, 2006 | 06:04 AM
so lazy's Avatar
Default Re: timing belt effed up............ (_DA9_)
there you go...
dbailey
Honda Civic (2001 - 2005)
Jul 30, 2016 09:33 AM
hammertime80
Apr 23, 2012 11:59 AM
nexgen91
16
May 8, 2007 06:39 PM
CRzex
Feb 15, 2002 09:55 PM
