Timing belt cover for correct timing?
Old Sep 12, 2005 | 06:21 PM
NACvicSi's Avatar
Default Timing belt cover for correct timing?
I am finishing touches on my Y8 swap. A friend of mine said that I have to have the timing belt cover to set the timing right on. Is this true, or can you set it withough one?
Old Sep 12, 2005 | 07:00 PM
EvilPinkEye's Avatar
Default Re: Timing belt cover for correct timing? (NACvicSi)
not sure what he, means by..needing the cover..but i think he's referring to the back timeing cover behind the cam..that if i remember has a notch that you use to align the cam with..dunno..hope i made sense...
Old Sep 12, 2005 | 07:13 PM
NACvicSi's Avatar
Default Re: Timing belt cover for correct timing? (EvilPinkEye)
the cover that is in the cover right?
Old Sep 12, 2005 | 07:30 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NACvicSi &raquo;</TD></TR><TR><TD CLASS="quote">I am finishing touches on my Y8 swap. A friend of mine said that I have to have the timing belt cover to set the timing right on. Is this true, or can you set it withough one? </TD></TR></TABLE>
yes u will need
the lower timing belt cover to set ignition timing
(without it how will u align the mark?)
Old Sep 12, 2005 | 07:39 PM
NACvicSi's Avatar
ok one is saying the lower, one is saying the inner. Which is it?
Old Sep 12, 2005 | 07:59 PM
rev-speed's Avatar
the lower timing cover is the only one u need
the top pice is not need
or the top inner
Old Sep 13, 2005 | 12:20 PM
NACvicSi's Avatar
Default Re: (rev-speed)
ok thanks a million man
Dan in Japan
May 20, 2008 06:33 PM
ahloung
Jan 22, 2007 08:25 AM
noble4ws
Nov 11, 2003 05:27 AM
Honda Kustums
Aug 19, 2003 06:36 PM
