Timing
Old Aug 30, 2002 | 09:40 AM
JoshRambo's Avatar
Default Timing
this may be a stupid question beut here it geos.
i am trying to adjust my timing. i have done it before and it worked fine. now i just want to check it. but for some reason the timing lights don't work.
i hook the up right. red to + battery, black to - battery and the other part to plug wire one.
well nothing happens. i have used 2 different timing lights and the same thing both times.
anyone know what i am doing wrong?
Old Aug 30, 2002 | 09:45 AM
Urban Business
Guest
Posts: n/a
Default Re: Timing (Gravity)
+ to red on battery. black to a GROUND not the battery clip thing on wire #1
Old Aug 30, 2002 | 09:47 AM
JoshRambo's Avatar
Default Re: Timing (TorteX)
thast doesn't work either
Old Aug 30, 2002 | 10:22 AM
C-speed's Avatar
Some timing lights require that then ignition pick-up lead MUST be oriented the correct direction when you clip it onto the #1 plug wire.. look for an arrow on the clip... if there is one, the arrow faces the driver side of the car.
redpeppers
Jul 25, 2005 09:39 PM
RicedREX
14
Sep 10, 2004 07:01 AM
BlueShadow
12
Aug 30, 2004 03:01 PM
MikeTV
May 5, 2003 08:15 AM
fe519
Nov 23, 2002 03:55 PM
