throwing code but no check engine light
Old May 9, 2007 | 06:20 PM
90civSi's Avatar
Default throwing code but no check engine light
a little background on the situation, i have a 90 hatch Si, i swapped a b16 in OBD0 and it ran fine. then i blew the differential and had to swap transmissions. When i got done swapping the new tranny on we had to jump it cuz the battery was dead. One of the ground on the battery wasnt connected and it arched. When i went to drive it it would not go past 3500 rpm sounded almost like it was boggin but just stays at 3500. If you are in neutral and hold the pedal to the floor it will go up to 6000 and come back down to 4000 and just stay there. I replaced the ecu and nothing, the resister pack nothing.
i just saw today that my i am throwing my tps code but the cell on the dash doesnt pop up. what else could be causing the engine to do this?
Old May 10, 2007 | 02:02 PM
90civSi's Avatar
bump
Old May 11, 2007 | 01:48 PM
90civSi's Avatar
Default Re: (90civSi)
bump
Old May 12, 2007 | 12:22 PM
90civSi's Avatar
bump
Old May 13, 2007 | 03:49 PM
arc_55's Avatar
did you fix the tps issue? I would re calbirate the tps and get that code removed, sounds to me like you have a dizzyy issue. This is definately an ignition issue.
Old May 14, 2007 | 07:02 PM
90civSi's Avatar
Default Re: (arc_55)
i havent fixed the tps yet havent had time but as soon as i do ill post what i find.
as for the dizzy i have pulled the cap off and the rotor and cap look fine even swapped dizzies and still nothing
Old May 18, 2007 | 01:40 PM
90civSi's Avatar
ok i checked the voltage at my tps at it was 0 and i would adjust it and it would read 1, so im thinkin my tps is toast so what tps sensors can i use on an obd0 b16?
L.T
Dec 5, 2017 09:42 AM
90civSi
15
May 20, 2007 01:04 PM
2camsaam
Oct 17, 2003 03:49 AM
IgniteTeg
Aug 8, 2002 09:26 AM
IgniteTeg
Aug 7, 2002 06:54 PM
