Throttle body question?
Old Mar 27, 2005 | 09:05 PM
Peligro's Avatar
Default Throttle body question?
I did a swap from an SOhc vtec to a LS and my LS throttle body has a broken TPS sensor. So i tried to use da sohc vtec TB but it comes with da Fast Idle Valve under the throttle body. And it doesnt fit cause the Ls manifold comes with one on it already. So i took da Fast Idle valve off the Sohc vtec TB, but it has ports opened. Will the throttle body be good enough if i cover up those ports with JB weld. I mean the LS TB didnt even have the Fast Idle Valve, since its already on the Manifold.
Old Mar 27, 2005 | 09:26 PM
Kendall's Avatar
Why don't you just swap the TPS's.
Old Mar 27, 2005 | 09:28 PM
Peligro's Avatar
Default Re: (Kendall)
I have no idea how to swap them. It doesnt come wit a screw that u can screw out.
Old Mar 27, 2005 | 09:59 PM
Redline130's Avatar
Default Re: (Peligro)
Use a Dremel (w/ a cut-off wheel) to make notches in the rivet heads, then you can use a flat head screw driver to unscrew the TPS.
Old Mar 27, 2005 | 10:09 PM
Peligro's Avatar
Default Re: (Redline130)
What if i dont have a dremel? And i have no idea what a river head is.
Old Mar 28, 2005 | 07:56 AM
PrettyLude's Avatar
use some kind of cutting wheel, a rivet head is what holds the tps to the tb
Old Mar 28, 2005 | 08:18 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Peligro &raquo;</TD></TR><TR><TD CLASS="quote">What if i dont have a dremel? And i have no idea what a river head is.</TD></TR></TABLE>
Go and get one, they are pretty cheap and come in handy all the time..
unix4linux
Apr 4, 2011 12:07 PM
95_red_dc
Sep 11, 2006 09:47 PM
Scud
Aug 9, 2006 09:58 PM
PhucNguyen57
Mar 25, 2003 11:50 AM
HondaCutter
Dec 4, 2002 03:05 AM
