threadlock question
Old Sep 19, 2004 | 11:24 PM
96MidoriHatch's Avatar
Default threadlock question
I put threadlock on my flywheel bolts and torqued it down, then the next day i realized that i forgot to put the damn bearing in so i pulled it off and of course the threadlock is all dried up on the threads and stuff. so my question is what is the best way to get the **** off? should i soak them in something or just chip away?
Old Sep 20, 2004 | 05:15 AM
-faded-'s Avatar
Default Re: threadlock question (96MidoriHatch)
should be able to scrape the stuff off.
Old Sep 20, 2004 | 06:05 AM
deSigi's Avatar
Default Re: threadlock question (hybridlsR)
I've never soaked it in anything, I would just get a nut of the same thread pitch and pass it through a few times. That always worked for me.
Old Sep 20, 2004 | 06:57 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Uh...tap and die?
Old Sep 20, 2004 | 07:57 AM
PURPLETERROR aka BIGMATT's Avatar
Use a wire wheel, or wire brush
Old Sep 20, 2004 | 11:33 AM
Default Re: threadlock question (PURPLETERROR)
thanks guys i figured i could just scrape it off with a wire brush or the nut trick, i was just wondering if you could loosen it up with some sort of solvent
HT Chaplain
Welding / Fabrication
Aug 1, 2007 12:35 PM
RACEPAK
Oct 20, 2006 01:06 AM
PrestonCRX
Apr 6, 2006 11:48 AM
b18bvudoo
Nov 11, 2001 10:40 AM
