Theroetically speaking..
Old Sep 4, 2006 | 10:12 AM
Boostage's Avatar
Default Theroetically speaking..
An oem oil pump on a b16 at 10,000-10,500 RPM is being stressed less than say a gsr at the same rpm right? I figure the b16 is a shorter stroke motor and has less vibrations. drastically reducing the chance of failure compared to the 1.8's
As far as I know, harmonic resonance is what destroys oil pump gears. so wouldnt a properly dampned b16 be able to see those rpms frequently without failure?
Old Sep 4, 2006 | 01:26 PM
Lsos's Avatar
Default Re: Theroetically speaking.. (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">An oem oil pump on a b16 at 10,000-10,500 RPM is being stressed less than say a gsr at the same rpm right? I figure the b16 is a shorter stroke motor and has less vibrations. drastically reducing the chance of failure compared to the 1.8's
As far as I know, harmonic resonance is what destroys oil pump gears. so wouldnt a properly dampned b16 be able to see those rpms frequently without failure?</TD></TR></TABLE>
Stresses in a rotating part rise exponentially with rpms. It has a limit whether it vibrates or not, although I have no idea what that limit is.
Old Sep 4, 2006 | 04:27 PM
schardbody's Avatar
GOT YOU ON AIM. hope i helped.
Old Sep 4, 2006 | 04:50 PM
OBRJosh's Avatar
Default Re: (schardbody)
Theroetically speaking.. If we went by the books then 8300rpm should break oil pumps cause thats the limit honda put on there motor, screw that **** go by what people have allready done not by what a book or some mathimatics. when it doubt REv It OUT
Modified by OBRJosh at 6:39 PM 9/4/2006
Old Sep 4, 2006 | 06:16 PM
schardbody's Avatar
Default Re: (OBRJosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBRJosh &raquo;</TD></TR><TR><TD CLASS="quote"> Theroetically speaking.. If we went by the books then 8300rpm should break oil pumps cause thats the limit honda put on there motor, screw that **** go by what people have allready done not by what a book or some mathimatics. when it doubt REv It OUT
Modified by OBRJosh at 6:39 PM 9/4/2006</TD></TR></TABLE>
yeah, umm, good point *rolls eyes* BUILT BEING THE KEY WORD. his question is will a built B16 that is capable of revving to 10k not tear up the oil pump.
the question was answered already via AIM, but more insight wont hurt.
Old Sep 4, 2006 | 06:27 PM
OBRJosh's Avatar
Modified by OBRJosh at 7:42 PM 9/4/2006
ALLMOTOR CRX
Jan 27, 2007 04:32 PM
b16vtecsol
Nov 18, 2003 12:45 AM
