Thermostat
Old Jan 19, 2002 | 06:59 AM
DOHCarp's Avatar
Default Thermostat
Hey, I was wondering what the signs of a bad thermostat are and where is it located on a B16A. Thanks.
Old Jan 19, 2002 | 07:03 AM
len's Avatar
len
Default Re: Thermostat (DOHCarp)
I do not know how to tell if it's bad off the top of my head. I would need to look at some books.
Hey I'm just learning like you.
But you can find the thermostat if you follow the top cooling tube to where it attaches to the engine. I believe there are three bolts holding the case in position. Once you remove that, you will see the thermostat.
Be forewarned that if you do open it, there will be coolant rushing out.
Old Jan 19, 2002 | 08:00 AM
iceburgslim's Avatar
As far as I know there is no way to tell if it's bad just by looking at it, but there are other signs. If your car overheats you could have a bad thermostat. If your car doesnt warm up at all and your heat doesnt owrk very well, that can also be your thermostat. Let us know if you are having either one of those problems. Later!
Old Jan 19, 2002 | 10:47 AM
DOHCarp's Avatar
Default Re: Thermostat (iceburgslim)
Yup the car takes forever to warm up and when I turn on the heat it cools back down really quick. Thanbks for the quick responses.
1a
Oct 18, 2007 08:25 PM
projectef
11
Jun 21, 2007 04:49 PM
teggyracer91
Mar 21, 2007 09:04 AM
hatchblack
Honda S2000
Mar 11, 2007 09:41 PM
allmotor.net
Apr 24, 2003 02:58 AM
