Are there serious effects if......
Old Feb 21, 2003 | 08:01 AM
Nate B's Avatar
Default Are there serious effects if......
My car originally was filled with regular 5w30 oil from the dealer, and I now use synthetic, but when making the change for the first time I just flushed the old oil out without running that alcohol stuff through to clean it real good. I've been using synthetic now for over a year and have noticed no problems what so ever, but I remember reading that some sort of solvent MUST be flushed through before making the change for regular to syn. Is this true that it's a MUST? and what can be the side effects of not doing so?
Old Feb 21, 2003 | 08:36 AM
JimBlake's Avatar
Default Re: Are there serious effects if...... (OG Bizzle)
No problem. You don't say what kind of synthetic, but the normal stuff (Mobil1? SynTec?) is compatible. Over a year? Changed oil more than once since then? That's even better. The few ounces that's left behind when you change doesn't hurt.
InspiredRacer's Avatar
So solvent needed
No results from the change. You can go back and forth as you please
Old Feb 21, 2003 | 12:15 PM
GripFactoR's Avatar
Default Re: Are there serious effects if...... (InspiredRacer)
u can go from regular to synthetic with no problem, but its not wise to go from synthetic to regular.
Old Feb 21, 2003 | 12:24 PM
dip-set's Avatar
Default Re: Are there serious effects if...... (VTECxSiR)
may i ask why....i use the mobil 1 synthetic blend 10w30...how much of a difference do u think the full synthetic will make as in : engine performance,less drag....etc....thanks
20-EM2-05
Honda Civic (2001 - 2005)
60
Jul 8, 2010 04:25 AM
sixtodc2
Feb 21, 2006 01:10 PM
ceemarun
Jun 21, 2002 05:33 PM
G2_Integ
Aug 11, 2001 09:13 AM
Mike D
Jun 23, 2001 07:26 PM
