theft deterrent system/fuel pump????
Old Mar 29, 2005 | 01:43 PM
TsukubaSpec's Avatar
Default theft deterrent system/fuel pump????
my integra 2000 gsr was a theft recovery car
I swap jdm b18cR 1998 engine
and ignition switch was from integra 98
and I use p2t Sir 1999 ecu just for trying to start the car but the fuel pump dont want to start (make nose when ignition was on)
I changed the main relay so its not the problem!!!the ground was fine too.
I read on my haynes repair manuel that the thetf deterrent system can be the problem,its kind of **** that'' not allow the PCM???? to signal the fuel pump relay or the engine to crank over''
where is this system was and what I can do to start the car????
my other problem was that im not able to turn my key to lock and pop out the key of the ignition but I can put accesories and start the car maybe its the cap with wires who was not compatible with my 1998 ignition switch???
Old Apr 11, 2005 | 06:17 PM
kbr56's Avatar
Default Re: theft deterrent system/fuel pump???? (DC2_StAr)
yo whats up u cant use a 1999 and up ecu cause there is a cut of module in the wiring that u wont turn on fuel pump and that u have to get obd1 jumpper harnes and use obd1 ecu to start ur car. i wanna know if u sent in to salvage unite yet because u better watch out there ******* basturads there cause u alot of problems have recieps for everthing or ur going to lose ur car
Smackinassvtec
Jan 16, 2014 01:35 AM
acidburn2k2
Dec 10, 2009 06:25 AM
lazylegs15
Sep 14, 2008 10:20 PM
TsukubaSpec
Mar 29, 2005 04:52 PM
2camsaam
Jul 14, 2003 09:09 AM
