Test Fuel Injectors?
Old Oct 28, 2002 | 11:41 AM
civicrtype's Avatar
Default Test Fuel Injectors?
I am getting a CEL code 16>>Fuel Injector Circuit. How do I test if Fuel Injectors are working or not?? What else should I check if they are working fine?? Thanks.
Old Oct 28, 2002 | 02:19 PM
Perfectionist's Avatar
Default Re: Test Fuel Injectors? (civicrtype)
With an ohm meter you can check the resistance of the coils. Should be about 1 or 1.5 ohms. You can also use a piece of solid material like a screw driver or wooden dowel and place it against each injector. Put the other end to your ear and listen for the injector ticks. If one is silent, that's your bad one. However, the engine would probably be running like crap. The ECU will set a code 16 if there is a break in the electrical circuit for the injectors. This might be a bad injector coil, injector resistors, wiring, or most likely an intermittent main relay.
Old Oct 28, 2002 | 02:24 PM
google's Avatar
Default Re: Test Fuel Injectors? (Perfectionist)
take a test light and connect it the the negtive on battery and then stick it into the colored wire on the injectors. red brown black blue and theyll pulse . if there pulsing then your good to go.
Old Oct 28, 2002 | 03:20 PM
civicrtype's Avatar
Default Re: Test Fuel Injectors? (1320in11)
thanks i will do that tomorrow.
Old Jan 5, 2006 | 10:21 PM
Daniel-sanB1's Avatar
thansk guys, this help alot
Old Jan 15, 2006 | 02:40 PM
Default Re: Test Fuel Injectors? (Daniel-sanB1)
i swapped my coil and main realy,
and I'm still getting this problem
Old Apr 27, 2012 | 11:12 AM
xpddc4's Avatar
i know this is old as hell but did u fix it? how so?
lamesa
Jan 2, 2015 04:06 AM
dayl
21
Apr 13, 2010 08:06 PM
SwappedTURBOegg
Aug 30, 2007 08:23 PM
GolfIVTyBiggums
Dec 19, 2006 10:12 AM
esqueleto
Oct 3, 2002 02:23 PM
