Tell the Difference Between LS and GSR Water Pump?
Old Apr 21, 2004 | 12:41 PM
vtecb20coupe's Avatar
B A N N E D
Default Tell the Difference Between LS and GSR Water Pump?
How can you tell the difference between an LS and GSR water pump? Is there a code on it that distinguishes the two? Thanks in advance.
Old Apr 21, 2004 | 02:45 PM
acy76's Avatar
Default Re: Tell the Difference Between LS and GSR Water Pump? (vtecb20coupe)
Count the teeth. The GSR has 22 (if memory serves; mine also has '22T' or something similar stamped on it), the LS has fewer - maybe 19. If you search around a bit, you can probably find the correct tooth counts just to be sure.
Old Apr 21, 2004 | 02:49 PM
B A N N E D
Default Re: Tell the Difference Between LS and GSR Water Pump? (acy76)
ok, mine says 19t on it. so, this would be an ls water pump then. just want to make sure before i install it with the wrong timing belt.
1ls/vtec
Jul 21, 2009 02:30 PM
grant97teg
Apr 27, 2009 10:44 AM
Eklsv-t
Dec 1, 2007 06:06 PM
DA is best
Mar 18, 2007 07:22 PM
alfee
Nov 28, 2005 09:37 AM
