telescoping gauge??
Old Apr 15, 2008 | 08:19 PM
b20vtech's Avatar
Default telescoping gauge??
ok just wanted to know if telescoping gauges can be use to measure crank journal housing?
Old Apr 15, 2008 | 09:02 PM
00b18b's Avatar
yep I don't see why not. I used a inside mic and used a outside mic to measure it. just take many measurements to compare your numbers.
Old Apr 16, 2008 | 07:10 AM
b20vtech's Avatar
Default Re: (00b18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00b18b &raquo;</TD></TR><TR><TD CLASS="quote">yep I don't see why not. I used a inside mic and used a outside mic to measure it. just take many measurements to compare your numbers.</TD></TR></TABLE>
so i can say forget the expensive 200-300 dollasr dial bore gauge?
Old Apr 16, 2008 | 08:09 AM
00b18b's Avatar
Default Re: (b20vtech)
bore gauges are sweet if you're going to be building engines quite often get that over the telescoping gauge. its much easier to use , but if $ is tight decide on whats going to suit your needs.
jetlude
Jan 2, 2008 05:50 PM
Topdawgg
Jul 3, 2006 01:11 PM
done
Feb 11, 2006 09:52 AM
ICeDoUt
Jul 18, 2005 01:33 PM
MooreBoost
Jan 11, 2005 07:46 PM
