Tein rear spring rate, why so low?
Old Mar 25, 2003 | 07:30 PM
ht834Crx's Avatar
Default Tein rear spring rate, why so low?
Can anyone tell me why the rear spring rate is so low
Honda CRX
EF9 88-91
269 front spring rate
123 rear spring rate
-1.5 front drop
-1.4 rear drop
Old Mar 25, 2003 | 07:36 PM
MattG's Avatar
New User
Default Re: Tein rear spring rate, why so low? (ht834Crx)
Probably to keep the car front biased.
Old Mar 25, 2003 | 07:40 PM
ht834Crx's Avatar
Default Re: Tein rear spring rate, why so low? (MattG)
thanks for the input, but isnt that a high spring rate for the front with the rear so low?
Old Mar 25, 2003 | 08:19 PM
Furry
Guest
Posts: n/a
thats the way they do it in japan..... high front with a lower rear, just the oppsite of the way us americans like it... go figure
Old Mar 25, 2003 | 08:43 PM
piscorpio's Avatar
Default Re: Tein rear spring rate, why so low? (Furry)
Durn crazy Japanese, engines rotate backwards, springs on backwards...
Old Mar 26, 2003 | 04:43 AM
CXHatchback's Avatar
Default Re: Tein rear spring rate, why so low? (piscorpio)
yeah well you don't want the rear to be soo stiff. The hatch part is light, and it's gonna bounce around if it's too stiff.
Old Mar 26, 2003 | 07:27 AM
goforbroke's Avatar
MEAT PATTY
Yeah I noticed the same problem with the Tein spring rate. They only get stiffer in the rear when you move up to like the RA which are around 600 front and 500 rear. I was looking at the SS and they are only 442 front and 224 rear something close to that. I was also looking at the H&R but their spring rate is similar also 450 front and 235 rear. I need something stiffer for autox but I don't have the dough for a $1600 system. So I don't know what to do. might just get ground control with adjustable koni. so many decisions not enough money, like usually. The Tein spring rate are mostly setup for street cars well the introductory models are.
Old Mar 26, 2003 | 05:43 PM
Ruby Civic's Avatar
Default Re: Tein rear spring rate, why so low? (goforbroke)
yea, when i looked into going tein ss with 400 front and 350 rear they wanted 130 each end for the upgrade and the very price i could get was about 1k...anybody got a better price...otherwise i will go ground control..
Old Mar 27, 2003 | 10:36 AM
Furry
Guest
Posts: n/a
Default Re: Tein rear spring rate, why so low? (Ruby Civic)
use the right tires and learn to left foot brake and the low spring rate in the rear will only make the car easier to drive fast. stiffer rear springs make the car twitchy and harder to drive fast
Old Mar 27, 2003 | 12:00 PM
sjracer's Avatar
they do that to induce understeer on a street driven car, well atleast that's true for the "american" products...a lot of oversteer with a high spring rate on the street gets dangerous...
i'm pretty sure if you have the Tein coilovers you can swap the front springs to the back and vice a versa...but with the spring rates that you have, being so low, i would just keep the stiffer ones in the front...late
Die-Laughing
Suspension & Brakes
10
Dec 31, 2008 08:12 AM
realis9
Suspension & Brakes
Apr 10, 2007 07:40 PM
Chong
Suspension & Brakes
20
May 22, 2005 11:24 AM
jond
Apr 12, 2004 07:19 PM
