TEG TRANNY HELP!!
Old Feb 5, 2010 | 12:40 PM
cghorr01's Avatar
Default TEG TRANNY HELP!!
Anyone know if i can throw a type-r trans on a gsr engine using stock axels and ****? I found a steal on a brand new jdm type r trans and dont wanna pass it up but i dont wanna to spend a ton of money to be able to use it. I have a 94 gsr in a 92 civic eh hatch. Car has a teg 4 wheel disc brake conversion on it.
Old Feb 5, 2010 | 01:16 PM
fcm's Avatar
fcm
Old Fart
Default Re: TEG TRANNY HELP!!
Pretty sure you will need the ITR 5 bolt axels.
I also looking for an ITR tranny for my 94 LS, the rest of the suspension will be aftermarket, I was told when looking into what is avalable, [lots] that if I went with the ITR tranny the axels are diff., [thicker]. 94
BTW what is a "steal", how much for the transmission?
Old Feb 5, 2010 | 06:38 PM
cghorr01's Avatar
1000 bucks for a brand spankin new JDM ITR Trans
Old Feb 6, 2010 | 02:19 AM
her_nhia's Avatar
Yes you can. As long as you're using any b-series tranny. Just make sure that you use your gsr halfshaft and axles. The type r's are the same but don't waste your time or $ buying them. The only thing you'd have to do is make sure you use manual transmission fluid from Honda, Pennzoil synchromesh, or Royal Purple manual transmission fluid cause they have the additives that's needed for the LSD.
NoobieREDLS
Apr 3, 2006 05:58 PM
rdeezy78
Aug 6, 2005 07:40 PM
tspkenneth
Feb 24, 2004 08:37 PM
totally jay
Feb 10, 2004 02:27 PM
that SCION girl
Jun 5, 2002 03:24 PM
