Swapping cranks?????? Which main should I use?????
Old Aug 17, 2004 | 03:33 PM
EGJDM's Avatar
Default Swapping cranks?????? Which main should I use?????
Hey
I am about to swap cranks in my block I am wondering should I use the mains from the original block or the mains from the crank that I am going to swap in?
Old Aug 17, 2004 | 04:29 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: Swapping cranks?????? Which main should I use????? (EGJDM)
Do you mean the main bearing caps? They definitely stay with the block they were machined with originally.
Old Aug 17, 2004 | 07:21 PM
EGJDM's Avatar
Default Re: Swapping cranks?????? Which main should I use????? (tjbizzo)
Yeah I am talking about the 5 mains should they be the original ones from the block or the ones from the crank I am putting in
Old Aug 17, 2004 | 07:28 PM
JDMotive's Avatar
Definately use the mains from the original block.Dont swap mains unless you have them align honed,as each set of mains is specifically machined for each block.
Jamison
Jul 15, 2011 11:20 AM
wantboost
Jul 17, 2004 08:44 AM
masterk0ns
Sep 15, 2002 04:35 PM
