swap probs, please help. accord peeps and super techs
im droppin a 94F22B into a 90 accord. done the swap, but the damn car wont start. it turns like .5 seconds then stops. i can turn the motor freely by hand except on compression stroke of course, but the starter wont actually continue to turn over the motor. any help would b appreciated. also, anyone know which fuse is the fuel pump fuse??? didnt mess with the pump but its not kickin on when the key is in the on2 position. i tried shimming the starter out too and still didnt work. also the motor was originally a auto, i used his existing tranny, flywheel and clutch. anyways, thanx guys, also, i did double and triple check main grounds including head grounds, tranny ground and dist grounds. thanx.
also, i used the stock accord harness and was goin to hardwire the VTEC pressure switch, VTEC and knock sensor.
we found the problem. cyl 4 was hydrolocking due to all the oil in the cylinder. i put a 3/8ths extension down the cylinder and about 1/2 inch worth of oil came out on the end of the extension. we fired the motor and blew out the existing oil then fired it up for the first time. it took a bit but eventualy it fired. another ? i have was is if 94 accord VTEC motors have a knock sensor??? i didnt see one on the block so i dont think it has one. any ideas how that oil built up in the cylinder??? thanx guys.
[Modified by hondaatwsu, 6:14 AM 4/21/2002]
[Modified by hondaatwsu, 9:53 PM 4/21/2002]
kevin916sfs
Aug 13, 2019 05:49 PM
