Swap is done.. car wont start!
Old Feb 14, 2002 | 09:20 AM
[626]95-GSR's Avatar
Default Swap is done.. car wont start!
I finally finished my swap.. but the motor wont start.. it turns over fine, but it just doesnt fire up. Heres the diagnosos: Checked for spark in the #1 plug wire.. NO SPARK.. checked to make sure fuel is getting to the fuel rail.. sure enough. It seems to be that there is no spark to ignite to motor.. ANY SUGGESTION?? i need the car for a date.. thank you in advance..
Old Feb 14, 2002 | 09:39 AM
Spade's Avatar
Default Re: Swap is done.. car wont start! ([626]Rj-SiHatchy)
Try a different plug wire to see if you get a spark that way. If so, ya got a bad wire. If not try a plug as well.
Old Feb 14, 2002 | 10:13 AM
Default Re: Swap is done.. car wont start! (Spade)
thanks.. wires are new.. and i also tried using other wires, i still cant figure it out.
Old Feb 14, 2002 | 11:56 AM
salbaje's Avatar
check grounds on block
Old Feb 14, 2002 | 12:26 PM
Kamin's Avatar
Default Re: Swap is done.. car wont start! (salbaje)
whats the details of the swap?
i mean gsr into
b16 into
etc etc
Old Feb 14, 2002 | 03:11 PM
dohcsideSi's Avatar
Default Re: Swap is done.. car wont start! (KAMiN)
yea you could check the grounds, when i first did my zc swap i had a bad ground and went through 4 ignitors , but the car started then died when it got hot, i would swap out the ignitor and coil if you got extras, if not borrow one of your friends distributors quicker if not easier than testing the coil and ignitor.
brandoom
23
Apr 10, 2009 03:33 PM
Cameron60
Feb 19, 2009 10:22 PM
Tad
Sep 5, 2007 09:51 PM
99sonicbluegsr
Sep 27, 2004 10:35 AM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
