Surging Idle
Old Jan 25, 2006 | 07:50 PM
SimplyTron's Avatar
Default Surging Idle
I have a B16 in my CRX and once it gets warmed up the idle starts to surge up and down from 700 to 1200 rpms. I have a AEBS intake manifold. I dont know what is cuasing this, I dont think it is a vacume leak becuase it doesnt do it until its warmed up. I thought it might be the FITV but I took the intake off and plugged the hole in the TB and it didnt stop. I dont know what else it could be. Any ideas?
Old Jan 25, 2006 | 10:12 PM
Takumi Fujiwara's Avatar
Default Re: Surging Idle (SimplyTron)
Have you set your base idle?
What I did was spray carb cleaner around the intake mani gasket, tb gasket and fitv gasket/block off (mine is blocked off too) to see if there were any changes to the RPM. Mine ended up being the intake mani gasket.
Old Jan 26, 2006 | 08:21 AM
SimplyTron's Avatar
When I unplugged the eavc the surging stoppped, but the idle was still high, i tried adjusting the screw and its all the way in and still idles at 1200 with the eavc unplugged. Does that mean the eavc is bad? I took it off nd clean the gasket and it still does it. should I try to spray it out with carb cleaner?
Old Jan 26, 2006 | 09:58 AM
Default Re: (SimplyTron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimplyTron &raquo;</TD></TR><TR><TD CLASS="quote">When I unplugged the eavc the surging stoppped, but the idle was still high, i tried adjusting the screw and its all the way in and still idles at 1200 with the eavc unplugged. Does that mean the eavc is bad? I took it off nd clean the gasket and it still does it. should I try to spray it out with carb cleaner?</TD></TR></TABLE>
The EACV is like the IACV on my car, with it unplugged, your idle should DROP. Especially with the idle screw on the trottle body all the way in, I'm pretty damn sure you have a vacuum leak somewhere. Mine was doing the same thing with an intake manifold gasket leak.
Turn your car on and spare carb cleaner around the gasket areas and see if your idle changes... if it does, you know it's leaking.
Old Jan 26, 2006 | 01:43 PM
itellyawhat's Avatar
mine does this too, driving me crazy. Do you have aftermarket exhaust? Would def. like to know what it is exactly.
^i used to have that problem but fixed it wen i first got my swap in.
Old Jan 26, 2006 | 08:19 PM
Default Re: (itellyawhat)
You have a vacuum leak, it's either a hose off the intake mani, the tb, or the intake mani gasket. You must find it. carb cleaner and time is your friend.
singlecammin
Jan 20, 2011 07:20 PM
93SiPrelude
Feb 24, 2008 10:39 PM
ericstambaugh07
Mar 13, 2007 05:10 PM
ULTRA911
Mar 4, 2003 10:00 AM
