surge in powerband, low idle..
Old Mar 11, 2003 | 02:25 PM
pg_thao's Avatar
Default surge in powerband, low idle..
i have low idle around 200-400, it seems like its going to die, i've tried adjusting the idle screw and its still the same.. the screw is almost out of the tb.. also when i rev the car it will also die and when it don't die it laggs thru out the power band..i've changed plug wires. check all grounds, spark plugs, dist cap and rotor, changed oil and pvc valve.. also changed the fuel filter..
any ideas?
Old Mar 11, 2003 | 04:06 PM
sslude's Avatar
Default Re: surge in powerband, low idle.. (pg_thao)
are you getting a check engine light? check all vaccuum lines and change your oil.
Old Mar 11, 2003 | 04:10 PM
pg_thao's Avatar
Default Re: surge in powerband, low idle.. (sslude)
there is no leak.. and changed oil.. still the same.. BUMP
accordmatt
Apr 27, 2012 01:06 PM
dth0ng69
Jun 28, 2008 08:04 PM
jojogalan
18
Jul 14, 2007 11:51 PM
b20acura
Jan 24, 2007 12:43 PM
jaycapz
Sep 2, 2004 11:32 AM
