Suggestions on a 11 sec all motor setup...
Old Oct 11, 2002 | 06:26 PM
powerfulperformance's Avatar
Default Suggestions on a 11 sec all motor setup...
I am building a somewhat streetable allmotor car. I am looking to run low 12 or posible 11 sec. I need any suggestions on what kind of compression i need to run, can toda c's get me into 11's, should i use a ls or gsr crank in my b18c1 block( at golden eagle) with 85mm bore. What's the advantage and disadvantage of using either one.
Parts that I have:
b18c1 block with 85mm golden eagle sleeves
b18c5 block
ls crank, gsr crank
itr head, b16 head
toda c
toda valve springs
portflow retainers
toda header
440cc injectors
Old Oct 11, 2002 | 06:58 PM
Default Re: Suggestions on a 11 sec all motor setup... (powerfulperformance)
Old Oct 11, 2002 | 09:43 PM
Tbone's Avatar
Steve s hit 230whp with a setup similar to that i beleive.
Old Oct 11, 2002 | 11:28 PM
MikeMAN's Avatar
Default Re: Suggestions on a 11 sec all motor setup... (Tbone)
JG Victor X intake mani/skunk2??
or overbore the stock one..
good luck!,
mike
Old Oct 12, 2002 | 12:14 AM
sieger's Avatar
If I had spent that much money I would have a pretty good idea what to do with it thus far... just go with what whoever is working on your car tells you to go with.. otherwise...
https://honda-tech.com/zerosearch
buffalos
Apr 29, 2013 06:06 PM
noobasaur
Sep 13, 2008 08:38 PM
hybridclassic626
11
Jul 27, 2007 09:25 PM
EGkid
26
Aug 25, 2004 06:28 PM
