This Sucks...HELP!!
Old Jan 3, 2003 | 09:10 PM
qwklude82's Avatar
Default This Sucks...HELP!!
After dropping my motor into my car and checking over everything I was about to start my car after priming the oil feed line to the turbo. I decided to make one last check underneath the car when i saw all this fluid leaking out. I found it to be coming from the transmission side of where the axles go into. What could be wrong? Is the rubber seal ripped? I know the problem isn't the axles, but I did notice that the axles are not all the way into the transmission side. There is about a couple cm, it seems, that it can be pushed into. Is all that is needed for the me to disconnect the knuckle and the control arm and push the axle all the way in or does this seem like there is a tear in the rubber seal of the transmission where the axle fits in.
Thanks
Old Jan 3, 2003 | 09:13 PM
Blown90hatcH's Avatar
Default Re: This Sucks...HELP!! (qwklude82)
More than likely the axle didnt go in all the way. Pull them out and double check the seals on both sides. They are only like 10 bucks from the dealer so that is an easy fix. Once you have verified those, then verify that the axles are going in all the way. Those are the 2 problems that I see occur most frequently.
J
Old Jan 3, 2003 | 10:04 PM
qwklude82's Avatar
Default Re: This Sucks...HELP!! (Blown90hatcH)
ok thanks
BTW i got the harness...thanks and nice christmas color wrapping of the harness
Old Jan 3, 2003 | 10:15 PM
ok thanks
Old Jan 3, 2003 | 10:17 PM
qwklude82's Avatar
hey this maybe a stupid question but i just wanna make sure. The fluid that is leaking is MTF right?
Old Jan 4, 2003 | 04:42 AM
b19coupe's Avatar
Yes.
Old Jan 4, 2003 | 04:47 AM
google's Avatar
Default Re: This Sucks...HELP!! (b19coupe)
just replace the axle seal its only 5 dollars and itll save you a headache later.
Jdm John
Dec 12, 2009 12:51 PM
keepitngga1
Dec 21, 2006 05:00 PM
type Gendy
Jan 19, 2003 06:18 PM
echo999
Jul 10, 2002 01:52 PM
Prelussion
Nov 15, 2001 12:51 PM
