Stupid engine code 19
Old Apr 3, 2003 | 02:40 PM
LudeToAHatch's Avatar
Default Stupid engine code 19
Sup guys,
I keep getting this stupid cel code and I don't understand why!! It's something like - automatic transmission cylinoid cable, or something along those lines... I don't have the code list in front of me... Anyhow, it doesn't make any sense! I have a 98 JDM Type-R tranny, not an auto. Why am I getting this code? Please help... It only comes on every couple days or so.
Thanks
Old Apr 3, 2003 | 02:43 PM
91DA9's Avatar
Default Re: Stupid engine code 19 (LudeToAHatch)
Are you using an automatic ECU?
What ECU are you using and are you sure you checked the right code list for the type of ECU you have?
[Modified by 94IntegraGSR-OVR, 6:44 PM 4/3/2003]
B18C-EJ1
Guest
Posts: n/a
It comes from your ECU, it's an automatic if you're getting code 19
Old Apr 3, 2003 | 02:44 PM
Default Re: Stupid engine code 19 (B18C-EJ1)
I'm not sure if it's an auto ECU... It's a P28 reprogrammed by Erick's Racing, I bought it from PitCrew
Old Apr 3, 2003 | 02:46 PM
91DA9's Avatar
Not nescessarily, if he is reading the wrong code list, or reading the flashes incorrectly.
Old Apr 3, 2003 | 02:49 PM
Default Re: Stupid engine code 19 (94IntegraGSR-OVR)
I'm pretty sure I'm reading them correctly... It flashes once, then a long pause, then nine short pauses... It does this over and over.
Old Apr 3, 2003 | 02:56 PM
91DA9's Avatar
Are you sure you checked the code list for your P28?
[Modified by 94IntegraGSR-OVR, 6:56 PM 4/3/2003]
Old Apr 3, 2003 | 04:19 PM
Kataku2K3's Avatar
That's typical for an AUTO ECU... It's just an automatic transaxle lockup solenoid CEL and it's not hurting anything... Check your ECU it will have something similar to this... 37820-P28-A00... What are your last three digits??? 37820-P28-xxx... I'm willing to bet that it's not A00, A01, A02 etc... those are all manual reversions... If the ECU's part numbers are no longer on the casing and female connector open up the casing and look at the board... About 3.25" in and 1.125" down from the connector side of the ECU you'll notice a 5 pin VTEC transistor... If you have a VTEC P28 board... (02D01720-1500 or the 11F0-1500)... If not then I doubt your VTEC is working... Anyways directly under it you'll notice two more 5 pin transistor sockets... IC16 and IC15 on the 1720-1500 board... These are the auto sockets... If you have transistors in them then you've got an AUTO ECU... If not then i'm not sure why you've got a CEL 20 up... hehe... Well Good Luck and I hope this helps
Old Apr 4, 2003 | 04:07 AM
JimBlake's Avatar
What's with the 'long pause'?? Doesn't that mean it's got two different codes? 10 and 9. Code 19 would be one long immediately followed by 9 short.
[Modified by JimBlake, 8:07 AM 4/4/2003]
Old Apr 4, 2003 | 09:56 AM
Kataku2K3's Avatar
Default Re: Stupid engine code 19 (JimBlake)
__|long flash|_|short|_|short|_|short|_|short|_|short|_|sh ort|_|short|_|short|_|short|_ Then ya got a code 19 which I'm pretty sure he is reading correct... If he's got an auto ECU then that's why the CEL is up... Really JimBlake you are correct about the way it was said in what you quoted... long ='ing a 10 ¤long pause¤ followed by 9 short ='ing 9... If this were the case something would most likely be messed up in the wiring/connections for the IAT and CYP... I'm just thinking it was stated a little bit off... Oh well, doesn't matter.... Peace
Old Apr 4, 2003 | 10:36 AM
JimBlake's Avatar
Default Re: Stupid engine code 19 (Kataku2K3)
Kataku's in Oregon & Lude...'s in LA, so I'm guessing you're not working together on the same car?
Kataku sounded a little unsure about reading the code. So if its really a long pause, then its two separate codes. If the space between the long & the first short is about the same as the space between all the other shorts, then he probably wouldn't have said 'long pause'. I hope I'm not being too much of a jerk, cause I'm trying to help.
Hope you get it figured out.
Old Apr 4, 2003 | 02:44 PM
Kataku2K3's Avatar
Yea man it's cool I'm just going off simply what you quoted... I'm just trying to help too, we're not working on the car together... I'm also NOT taking any of this personally but why do you say I sounded unsure about the code??? It's not that hard... I was simply responding to what you said.... Like I said, I agree with you... If there is a long pause between we are dealing with two separte codes... But I personally think that he simply "miss typed" what you quoted... For just running an AUTO ECU do you think he's gonna get a IAT and CYP code??? An automatic transaxle lockup code would make a lot more sense wouldn't it... Oh well, doesn't matter... Peace
Old Apr 4, 2003 | 03:43 PM
Actually, it's more like:
|short|____|short|_|short|_|short|_|short|_|short| _|short|_|short|_|short|_|short|
BTW, sorry for taking so long to resond, for some reason, I was unable to post more than 5 times in a 24hr period
[Modified by LudeToAHatch, 12:45 AM 4/5/2003]
Old Apr 4, 2003 | 04:29 PM
Kataku2K3's Avatar
Okay, well then you have a code 1 and a 9... That's not an automatic transaxle lockup code which makes me wonder if you truely have an auto ECU... Latez
Old Apr 7, 2003 | 06:10 AM
JimBlake's Avatar
... but why do you say I sounded unsure about the code???...
Because I was confused about which one of you guys I was talking about. I meant that it sounded like LudeToAHatch was unsure of which code he was seeing. I get myself in trouble by not scrolling back up & making sure what I'm doing.
Now it sounds like code 1 along with code 9. He wasn't really sure if he had an ECU for automatic, since he got it from Erick's Racing. Codes 1 & 9 should be the same for auto or manual anyway.
Old Apr 7, 2003 | 04:16 PM
Kataku2K3's Avatar
hahaha, it's all good... I understand now... Anyways if you wanna find out if the ECU is auto or manual do what I said above... Good Luck
hondaz6lx
Jan 29, 2007 09:51 AM
crxtreme27
Feb 4, 2004 10:19 PM
maximedx
May 28, 2002 08:03 PM
Jeef
Dec 9, 2001 06:35 PM
