stuck oil filter
Old Jul 11, 2004 | 01:16 AM
kliq's Avatar
Default stuck oil filter
was doing an oil change on the EG today and the oil filter wasnt coming off, even with the filter wrench.
i was pressed for time so i just filled it up with fresh oil and away i go.
would it be best to try again soon or can i wait til the next oil change (3000miles)
thanks in advance.
Old Jul 11, 2004 | 02:24 AM
timmy8151's Avatar
Default Re: stuck oil filter (kliq)
Try getting a strap wrench around the filter. Another option would be to use some sandpaper to try to get some grip. The last and messiest option would be to puncture the filter with a screwdriver and then taking it off.
You can wait till the next oil change to replace your filter. Most filters can easily go 7-8K miles without changing.
Old Jul 11, 2004 | 04:07 AM
Xsi's Avatar
Xsi
Try one of those wrenches with 3 prongs that grip around the filter or just stick a screwdriver through it like you said. Next time just do it up hand tight and you won't have a problem getting it undone. It won't kill your motor to change it next time.
Old Jul 11, 2004 | 09:02 AM
slo2kgsr's Avatar
Default Re: (Xsi)
I found the best tool is the cup with a spring in it the more you turn it with a ratchet the tighter it gets and will eventually come off.
bought it off the snap on truck hehe
sears has a cheap one with 3 prongs that doesn't work as easily but should work none the less
Old Jul 11, 2004 | 10:54 AM
taz77's Avatar
New User
Default Re: (tegraLS97)
http://www.thetoolwarehouse.ne....html
this is like, the best oil filter wrench available out there, unless you need the wrench type of course. just about everyone i know at toyota and honda has one. even the guys i don't know.
Old Jul 11, 2004 | 02:26 PM
murtnabila's Avatar
Default Re: (taz77)
I have one from kragen that is like a pair of pliers and works great! B4 buying that when I had one on that wouldn't open a flat head screw driver and a hammer did the trick
Old Jul 11, 2004 | 09:25 PM
Quitripin's Avatar
get a thick rubber band that will give you more hand grip. left loose right tight
Old Jul 11, 2004 | 09:35 PM
YellowCivicE's Avatar
If all else fails get a screw drived hammer a hole through both side and use the screw driver as leverage to turn it. I dont recomend this but it worked for me.
Old Jul 11, 2004 | 11:09 PM
Schmitey's Avatar
Default Re: stuck oil filter (YellowCivicE)
Fellas, this is why you use K&N oil filters. They have a 21 mm nut welded to them for easy removal. They're as much as wix and do a better job!!!
Old Jul 12, 2004 | 12:33 AM
kliq's Avatar
thanks for the input guys.
but my question was is it ok to wait for my next oilchange to replace the filter. hehe
but thanks for the tips!
Old Jul 12, 2004 | 01:39 AM
Lance C's Avatar
Default Re: stuck oil filter (Schmitey)
to me an oil filter is an oil filter.... i dont think your going to have any problems with a STOCK one....
yoitz2tone
Acura TSX
30
Jan 22, 2009 07:42 AM
00ls1
Aug 1, 2008 07:48 PM
norcal450
Honda Civic (2006 - 2015)
22
Oct 5, 2007 12:20 PM
digdug18
30
Sep 13, 2005 05:12 PM
Type Goch
Jul 1, 2001 10:11 AM
