Stripped tranny fill hole
Old Jun 22, 2008 | 05:25 PM
seeholmes's Avatar
Default Stripped tranny fill hole
After changing the oil in my vx MT I overtightened the fill plug and stripped the hole. I can tighten it enough to drive but dont feel confident it wont loosen and or leak. I am considering applying JB weld to the threads to seal it up permenantly. If I do, I can fill through a different spot for future oil changes. Any advice or opinions? Thanks
Modified by seeholmes at 6:32 PM 6/22/2008
Old Jun 22, 2008 | 06:16 PM
Cyphear's Avatar
You can fill it through the VSS sensor hole. You can fix it with a helicoil if you want to fix it right.
Old Jun 22, 2008 | 07:59 PM
seeholmes's Avatar
Default Re: (Cyphear)
Thanks for the suggestion. Any idea what the thread size is of the fill plug? I know the socket is 17mm but the thread is huge. I can hunt around for a helicoil kit locally tommarow. Thanks.
Old Jun 22, 2008 | 08:14 PM
downest's Avatar
Default Re: (seeholmes)
You can also use the reverse light switch hole on a D tranny, its a little easier to get to.
Old Jun 22, 2008 | 08:17 PM
Cyphear's Avatar
My guess is that it's probably M14x1.25 or M12x1.25, but you'll want to check to make sure. If you car is a beater you can change it and then JB weld it on there, then hope that lasts the life of the car, but if it's a nice car it's probably best to buy the helicoil and spend the time fixing it right.
civicboy420
22
Aug 7, 2014 01:20 PM
JASIYAH6
Mar 9, 2009 10:05 AM
slor209
Feb 6, 2007 05:38 PM
Rex89
16
Jan 2, 2007 06:24 PM
89crx23
May 23, 2005 10:19 PM
