Stripped threads
Old May 28, 2006 | 09:51 AM
Adam1994ls's Avatar
Default Stripped threads
I have a 94 ls and I had to put a new tranny in it cause I blow the old out at the track. There are the 3 bolt holes right on top of the tranny for the top tranny mount, but 2 of them are stripped out, would I be able to use a heli coil, would it be strong enough. I can't really find any heli coil that size either. I thought about just getting a little bigger bolt and taping bigger threads but I don't know about that either. Any suggestions about maybe where to go or what do to?
Old May 28, 2006 | 10:02 AM
LSVTEC 91 Civic's Avatar
Banned
I had the same issue. I found some longer bolts, and some washers... and It worked.
Ghetto.. but I was in a hurry to get it together, and I didn't have time for helicoils.
Old May 28, 2006 | 10:06 AM
Adam1994ls's Avatar
Default Re: (LSVT3K 91 C1V1C)
whatever works. I can't even find any longer bolts of that thread pitch
Old May 28, 2006 | 11:25 AM
b16_DIM's Avatar
Default Re: (Adam1994ls)
Can't you just tap in a larger bolt size? the top mount should be pretty easy to access, id just go two, maybe three sizes larger. I think most helicoils are two sizes larger so three for tapping would probably work out just fine...
fndbt
Apr 6, 2011 05:58 PM
NAallthewayEM1
Jul 13, 2010 03:00 PM
guedo148
Jun 24, 2010 11:16 AM
NastyGSR
Oct 5, 2003 06:25 AM
ijjz
Jul 10, 2003 09:32 PM
