stripped spark plug wire.....
Old Feb 12, 2004 | 01:37 PM
genetsang's Avatar
Default stripped spark plug wire.....
i was changing my Cap and Rotor on the dizzy.... and when i was pulling one of the plug wires... the metal connector was stripped from the plug wire and was stuck on the cap...
anyways... i was just wondering if it is ok to run 2 different type of plug wires temporarily.... just so that i can run and pick up a brand new set of wire?
my set up was... a set of MSD 8.5 mm Super Conductor wires.... but one of the MSD wire connectors was stripped.. so i replaced the stripped MSD wire with an used oem plug wire from a while back...
CURRENTLY im running 3 MSD wires and 1 OEM plug wire...
is it cool for me to drive it to honda to pick up a set of new wires?
thanks
Old Feb 12, 2004 | 01:41 PM
tegmech's Avatar
yep, you won't really have any problem
Old Feb 12, 2004 | 02:17 PM
genetsang's Avatar
Default Re: (tegmech)
true thanks.. any more insight?
Old Feb 13, 2004 | 05:32 AM
integra6650's Avatar
Default Re: (genetsang)
try nology im curious about them
Old Feb 13, 2004 | 09:23 AM
RCautoworks's Avatar
Default Re: (integra6650)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra6650 &raquo;</TD></TR><TR><TD CLASS="quote">try nology im curious about them </TD></TR></TABLE>
There garbage
Old Feb 13, 2004 | 09:26 AM
Sliced Beard's Avatar
Default Re: (90blackcrx)
not worth the money
just buy a good set of wires
i personally use accel wires an they work great
Old Feb 13, 2004 | 09:31 AM
Default Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">
i personally use accel wires an they work great</TD></TR></TABLE>
Same here, never had a problem with them at all. Would recommend them to anyone
Old Feb 13, 2004 | 12:25 PM
fox297's Avatar
I have one too. Not sure if it made any improvement over stock, but it's holding up okay.
Old Feb 13, 2004 | 08:05 PM
Stripped Honda's Avatar
99-0104
Default Re: (fox297)
i will stick with stock or ngk wires they last the longest
LawlessOne
Mar 13, 2012 12:35 AM
777
10
Jan 18, 2006 08:28 AM
johnclaunch
Aug 18, 2004 03:06 PM
