stripped oil pan bolt help!!!
Old Jan 28, 2006 | 06:24 AM
herreragta's Avatar
Default stripped oil pan bolt help!!!
ok my friend was trying to change the oil on his car and instead of losing the bolt he was tightening instead so the bolt strip and now it won come out , is there any way to get it out please help
Old Jan 28, 2006 | 07:56 AM
old man neri's Avatar
Default Re: stripped oil pan bolt help!!! (herreragta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herreragta &raquo;</TD></TR><TR><TD CLASS="quote">ok my friend was trying to change the oil on his car and instead of losing the bolt he was tightening instead so the bolt strip and now it won come out , is there any way to get it out please help</TD></TR></TABLE>
Did he strip it or just shear the head off?
If he sheared the head off you can probably go down to you local autoparts place or hardware store and get a bolt extracter, there are various kinds. It should work cause the bolt is not ceased in there. Also the threads should be still intact.
If the stripped it and it is spinning freely, well..hmmmm. Probably have to just pull it out, either re-tap the hole to somethign bigger or insert a helicoil. Also get a new train bolt. That's all I can think of. Might want to think about an engine flush because there will be some debris in there. Or drop the pan.
Any pictures?
Cheers and good luck.
GsrTurboCRX88
19
Nov 21, 2006 06:12 PM
95TEG
Jul 7, 2004 05:53 AM
Blaze45
May 18, 2003 10:53 AM
h46it
Apr 7, 2002 05:22 PM
FuzzyGreen
Feb 13, 2002 11:10 AM
