Stoopid Question
Old Apr 27, 2002 | 11:52 AM
SlowB16's Avatar
Default Stoopid Question
When you take the valve cover off is there anything special you have to do? Or do you just unbolt it and pull it off?
Old Apr 27, 2002 | 11:59 AM
94civicx's Avatar
New User
Default Re: Stoopid Question (SlowB16)
yes, you unbolt it and remove the head gasket by carefully peeling it off, that's it
Old Apr 27, 2002 | 12:11 PM
SlowB16's Avatar
Default Re: Stoopid Question (94civicx)
Head gasket? All I want to do is take the valve cover off to paint it.
Old Apr 27, 2002 | 12:35 PM
94civicx's Avatar
New User
I'm sorry typed the wrong thing. you just need to peel off the valve cover gasket. It should come off when you take off the valve cover but if not peel it off carefully
Old Apr 27, 2002 | 01:37 PM
khoalie's Avatar
it may not want to come off at first.
if this happens resists the urge to grap a screwdriver and start prying,
this could nick the surface on the head and the thing will not seal with nicks
get a rubber mallet or something and hit it on the side to loosen it
hope this helps
Old Apr 27, 2002 | 01:46 PM
SlowB16's Avatar
Default Re: Stoopid Question (khoalie)
Ok thanks alot
Old Apr 27, 2002 | 07:06 PM
owen_the_soyboy's Avatar
when you reinstall the valvecover/gasket, you should put a bit of liquid gasket (aka hondabond) at the 'sharp' corners where the gasket makes a 90 degree bend to go up and over the cams. this is important to avoid leaks, a leak near the timing belt can be a problem if enough oil leaks out under hard cornering to get in between the belt and the crank pulley.... skip = bad
GsDAteg
Jan 31, 2009 05:03 AM
dohcteg
Dec 23, 2006 12:03 PM
miksew
13
Oct 20, 2006 05:48 PM
Lil Corb
Feb 23, 2006 12:53 PM
Hans
Mar 11, 2003 06:19 AM
