Stock gsr ecu pigtail
Old Dec 19, 2013 | 01:16 PM
jdragon1974's Avatar
Default Stock gsr ecu pigtail
So I have a question. i'm running s300 on my 95 integra and who ever owned the car before me did a hack job on the wiring, so I have a few wires that are hanging on by a thread and I'm thinking it is wires to the injectors, would this cause a slight miss fire if the injector is not responding the way that it should? I moved my ecu and blew the ecu fuse so ZI figure it cant be good lol.
Old Dec 19, 2013 | 07:16 PM
Mad Fab Lab's Avatar
Default Re: Stock gsr ecu pigtail
Disconnect battery until you go over and properly fix all the wiring or you will just cause more issues. Just moving the ECU will not cause a fuse to blow unless you have a wire shorting somewhere.
Old Dec 20, 2013 | 06:30 AM
OK, got you, thank you for the info.
jmpassey
May 31, 2018 06:46 PM
Jimmy Wyrick
May 6, 2013 11:15 AM
onepoint-gsr
Feb 28, 2006 01:55 AM
killa_lude
Jan 10, 2004 12:45 PM
