Still having issues with restarting
Old May 7, 2002 | 10:46 AM
1hottEG6's Avatar
Default Still having issues with restarting
Ok, so yesterday i got a lot of help from some techs. However nothing seemed to work. I basically used a brand new ECT and my engine still won't start when hot. So today i learned that if I take out the ecu fuse and let it sit for a minute, it will start.? any suggestions..thanks
btw
-my fuel pump does turn on when i when i turn the key(so im thinking the relay is good)
-engine cranks, but does not turn over
-and my radiator fan is not turning on sometimes...?
Old May 7, 2002 | 02:32 PM
Chiovnidca's Avatar
Default Re: Still having issues with restarting (B20eg-T)
Did you check the ground wire connection at the t-stat housing?
Old May 8, 2002 | 06:47 AM
88_SC_CRX_Si's Avatar
New User
OOOPPPSssss
ADDED - Might have a look at you igniter, if you have not already.... It could be failing do to heat
[Modified by 88_SC_CRX_Si, 7:06 AM 5/9/2002]
blaze_125
56
Jul 13, 2010 07:00 PM
sicegcivic
Apr 24, 2008 11:23 AM
TurboEK9Coupe
Apr 24, 2007 04:43 AM
1hottEG6
May 8, 2002 12:38 AM
1hottEG6
May 7, 2002 02:17 PM
