Still curious... someone respond this time
Old Dec 22, 2005 | 07:28 PM
voiceinurhead05's Avatar
Default Still curious... someone respond this time
I posed this question on the accord forum, but didnt get much of an answer. I have a 1989 Accord LX with an A20A1 engine. I recently had the idea of building a frankenstien using the stock A-series block possibly with an expanded bore, but I'm not sure what head would be best to use for this (yes, I realize that this will require custom made bolts). Obviously, I would do away with the 2bbl carb and replace it with a multi point FI system. I just know that in order to do anything with this block, the 12-valve head has to go. So, what (if anything) would you guys suggest?
Old Dec 22, 2005 | 09:04 PM
4dohs4mohoes's Avatar
Default Re: Still curious... someone respond this time (voiceinurhead05)
I used to have an 88. Doing what you say is a big waste of time and money. Yes it would be best to convert to MPFI, but that isnt easy. And if you were to convert. just throw either a H22 or F22 into that biotch. Or you can put a webber carb on it.
J.B.Motorwerks2
Aug 11, 2013 01:38 PM
flipmoderacing1
Nov 12, 2010 06:45 AM
d-rail
Oct 7, 2008 05:02 AM
WH0R3nEF9
Oct 4, 2006 12:09 PM
