Steering doesn't return, what cause??
Old Jan 6, 2003 | 06:33 PM
SixPAK's Avatar
New User
Default Steering doesn't return, what cause??
My steering wheel doesn't seem to want to return to its center position after turns. I would like to know what parts exactly are causing this problem. I have heard it is the tie rods but can someone show me with a diagram? It's a 99 Civic.
[Modified by SixPAK, 3:34 AM 1/7/2003]
Old Jan 6, 2003 | 06:40 PM
smokin rubber's Avatar
Default Re: Steering doesn't return, what cause?? (SixPAK)
Tie-roda "should" still be fine. Were you in an accident, or hit a curb? I would get an alignment, that is most likely the cause.
Old Jan 6, 2003 | 07:19 PM
SixPAK's Avatar
New User
Default Re: Steering doesn't return, what cause?? (smokin rubber)
I have been in an accident before, but that was a long time ago and isn't the cause. I don't mean that the wheel is not centered. What I mean is that usually when you make turns, the steering wheel will automatically reutrn to the center position. On my car it never really automatically returns and I have to manually turn the wheel so it will be straight again.
Old Jan 6, 2003 | 07:39 PM
tominos's Avatar
hmm, maybe the tie rod ends are starting to go. i learned about it in auto shop, but been a while.
Old Jan 6, 2003 | 08:08 PM
texan's Avatar
Get an alignment, and make sure to have the SAI and scrub radius checked along with the all important caster. These are the three main alignment concepts that determine the self centering ability of the steering system. Your steering wheel may be perfectly centered but if something's bent or way out of alignment, the self centering effect can disappear.
215civic215
16
Mar 10, 2013 10:30 AM
NEO_FOLLOWER2
Jun 13, 2011 03:56 AM
Jet Black
Jan 24, 2004 06:54 PM
kb798
Jul 4, 2003 07:19 AM
