Starting Problems after DIY valve adjustment.
About two weeks ago i hunkered down in the garage and did the DIY Valve Adjustment. i adjusted everything into spec; checked over clearances / tq. ratings all that like 800 times. car started up just fine, no more valve tick, i was pretty excited
the next morning i went to go start my car for work, and it took about 10-15 more cranks than usual to start my car. i thought it was weird but my car was running after that perfectly.
today, when i got in my car to come home from work, when i went to start my car, it cranked once and then just stopped. when i tried to crank it again, it was like my starter had died. no clicking, no turny-turny. nothing. took the key out, looked inside the engine bay for loose wires / blown fuses and what have you. went back in the car, and it started up just fine.
my question is if any one else has had starting problems and the like after doing a valve adjustment. i read in another topic on this that turning your crank clockwise is a bad move, but didnt hear anything about damage because of it. i know that for the most part, i turned the crank counter-clockwise when i was doing the adjusment but went clockwise to make sure that i was at TDC and all that.
thanks.
Ben
thanks.
Ben
i take it 2nd gen (according to his SN) might me a 2G CRX. If it's OBD0 it doesnt matter if you reset the ecu because it dosent learn anything... it's retarded
having a main relay go bad sucks
but having the harness ground loose sucks even worse
check to see if your harness ground is loose, it is located on the thermostat housing. If this is loose YOUR CAR WILL NOT START, the fuel pump wont even prime.
2 hours of troubleshooting one time trying to figure out something that simple SUCKS
actually, its a 93 Integra LS(special edition)
but i checked all the connections and everything. the battery is fine, alternator is fine. its only happened twice, and it was quite aways, time wise, apart when it had problems starting. oh well, it still works. thanks for the input guys. time to go change my babys blood. peace.
Dwight Schrute
28
Feb 27, 2018 09:43 AM
patrickvertigo
Mar 10, 2008 04:29 PM
