Starting problems
Old Jun 27, 2007 | 10:37 AM
white_panther's Avatar
Default Starting problems
Hello I have a 94 Accord stock to the bone, like a year ago I replaced the stater and solenoid on it because it was giving me a hard time starting it and it worked. Yesterday night when I tried to start it I could not get it to crank, and my friend jumped it and it started in a breeze. Ran for a while so it would charge the battery and this morning it cranked, but with a lot of difficulty, checked the batery and it has 14.3 V, is their a way to check how much power the starter is receiving? Or test if the starter is the problem?
Thanks
Old Jun 27, 2007 | 12:30 PM
King V's Avatar
Default Re: Starting problems (white_panther)
14.3 volts is too much for a battery, unless you checked it with the engine running. A battery in good shape should have 12.8+/- 0.1 volt or so. You might have shorted plates or a sulfated battery.
Old Jun 27, 2007 | 12:43 PM
Default Re: Starting problems (200kCivicSI)
I did check it when running (without thinking), then I re-checked it a it was a 12.4 V when I took the battery out, and it is clean no acid.
Old Jul 9, 2007 | 05:08 AM
King V's Avatar
I would have the battery tested at your friendly local auto parts store. If it comes up OK, i would check the power and ground cables off the battery for corrosion, breaks, brittleness, etc, and check the starter solenoid wire(s) for the same.
Aug 13, 2010 09:14 PM
thaisayz
17
Feb 11, 2010 09:19 AM
mysterysktr7
Jul 10, 2009 09:09 PM
SiB16A
Jun 11, 2006 12:37 PM
incognito E46
May 30, 2005 05:06 PM
