Starter signal fuse keeps blowing
Actually that is incorrect. An excessive draw is not a fancy name for a short. There are shorts to ground and shorts to power and determining which is in effect will determine the diag path to proceed with. An excessive amperage draw by a faulty motor or solenoid is a whole different problem. Any how I had not read that you have already determined it to be a short. I thought the OP was still trying to figure out what was wrong. Carry on....
So I checked the bluw/white white from the plug and it has continuity to body ground, I checked between the green/yellow wire from the main relay to ground and it has continuity, then I check between the two yellow/green wire from the main relay for continuity because from what I believe the diagram shows that it shouldn't have any with everything at off, but it does have continuity between eachother which they shouldn't, is this correct or am I wrong. So I'm thinking it could be part of this?
I would expect that only one of the two sides of C131 (dash fuse box versus ECU side) has continuity to ground. Is this what you found? If so, which side?
I assume you bypassed C131 for the rewiring. Is this correct?
The fact that the new wire did not repair the short suggests that it is in or near one of the connectors (C420, ECU, main relay). If you did not bypass C131, then it is also a candidate. Results from your earlier C131 test may allow you to rule out the ECU side of C131 and the ECU connector.
If you now cut the Blu/Wht wire near each unplugged connector, you can test the cut wire for continuity to ground to determine whether the connector itself has the short.
And what plug are you referring to here:
From the c420 plug, I splice two new wires that goes one into the main relay and the other to the ecu to replace the two blue/white wires. I check continuity from both of the new wires to body ground and it showed it did on both. So I check continuity without the new wire that is going into the main relay by itself to see if it is getting grounded from the main relay itself. The reason I check the yel/grn wires that is coming out of the main relay is because from what I can understand shouldn't haven't current going through it with the engine off correct? So that's why I check in thinking that it could be getting a short from the main relay itself.
Was C420, the main relay connector, and the ECU connector unplugged when you did the continuity to body ground test? If so, as I have already said, this tells you that the short is in either connector C420, the main relay connector, or the ECU connector. I have already described how to pinpoint which connector has the short.
Why do you think the main relay has a short? Your tests already eliminated this possibility.
i think im gon have to redo some of the test to be sure of things, the reason i was thinking it's through the main relay is because the fuel pump stays on at the ON position.
Okay, i got the car running perfectly now. thank you for all the help man...couldnt have done it without ur help RonJ@HT. ive been driving it for about 2weeks now, 1200 miles on the new engine and everything is good...thanks again.
ThatOne02Accord
Jan 24, 2013 02:50 PM
CivicSi95
16
May 8, 2010 06:29 PM
