Standard base model(2)
Old May 16, 2003 | 10:40 AM
thevtecnician's Avatar
Default Standard base model(2)
Aite, i have a 1988 base model civchatchback. It doesn't run, unless you push-start it. I dont know what is wrong with it, the starter gets no signal at all(i know this because i push started it and tried to crank the motor with it running, and nothing happened. So, what the hell could it be?
its not the starter, battery, groundconnection, ecu, mainrelay, wiring harness,startersolenoid,loose wiring connection, ignition switch(oh yeah, the car got stolen and peeled ignition)any other ideas or is there someone that had a similar problem?
Old May 16, 2003 | 10:42 AM
Default Re: Standard base model(2) (thevtecnician)
alot of people are going to offer suggestions, but i replaced everything to test the problem. I even replaced the ignition switch, fuse box, wiring harness, starter, alternator,fuses, nothing seems to work, the car just got stolen so maybe theres a problem with wiring? my homies car has a peeled ignition with just the white switch showing, but his start rite up
Jochem17
Apr 10, 2018 11:43 PM
EJ8ronnie
Oct 29, 2007 04:14 PM
spurge
Jun 24, 2006 01:58 PM
baastard
May 25, 2006 07:52 PM
thevtecnician
Dec 12, 2003 07:42 AM
