ST sway bars ? help
Old Sep 9, 2003 | 08:01 AM
ScottFern's Avatar
Default ST sway bars ? help
I have a used rear Suspension Techniques and a new Front sway bar, but I am missing a couple rear bushings(pic) for the front, and the endlinks for the rear are cut(pic).
What a catastrophe....anyway, I wanted to ask where I might be able to find these extra bushings/links ?
That pic is of Enery Suspension set, however, I am running ST bars, and not sure if those bushing are compatible. If anyone knows, let me know....
I have the ST sway bar set for a 92-95 civic without a front sway bar (CX)
Old Sep 9, 2003 | 09:06 AM
advanracing62's Avatar
Default Re: ST sway bars ? help (ScottFern)
I've found that the ES bushings are smaller in overall diameter than the ST ones, I think the ES bushings for the GSR/ITR are bigger and more suited for the ST kit. I've replaced some of my bushings with large, flat, thick washers that sandwich the bushing (or what's left of it). The washer's have not bent or caused anything to break... yet. What can I say? I'm a chinsey bastard! HTH
Old Sep 9, 2003 | 10:41 AM
ScottFern's Avatar
Default Re: ST sway bars ? help (advanracing62)
so I can run the ES bushing set ? My only question is....now what size should I get ??? I dont want to order the wrong set
Old Sep 9, 2003 | 11:09 AM
I'd double check the PN for the GSR against the EG.. I know that the Accord ones are really small so no need to check them. I'll see if I can't find out before you do...
Old Sep 9, 2003 | 02:14 PM
ScottFern's Avatar
I found out the 92-95 civic front bar diameter is 3/4" and same with the rear bar.....I don't know if that helps...but I can't find a website selling the ES anti-sway bar stabilizer bushing set ?????
Front Sway Bar Frame Bushings, 24mm, 16-5104, $6.77
22mm, 16-5108, $6.77
21mm, 16-5105, $6.77
Rear Sway Bar Frame Bushings, 15mm, 16-5117, $6.77
13mm, 16-5107, $6.77
If I could only figure out how many mm's 3/4" is ?
ScottF
Sep 17, 2012 04:15 PM
dgerej2
Suspension & Brakes
May 21, 2010 05:55 AM
kelvinchau25
Jul 16, 2005 12:23 AM
Karterguy13
Apr 28, 2004 10:46 AM
ScottFern
Sep 9, 2003 08:17 AM
