SRS cluster is on? How do you turn it off?
Old Nov 19, 2002 | 07:02 PM
Audio28's Avatar
Default SRS cluster is on? How do you turn it off?
I have a 96 Integra. When I bought it, the air bags had already been diployed. The guy that I bought it from replaced it with the wrong year bags, so the light is on. How do I get this light turned off. I already tried to take the srs fuse, but that didn't work. Thanks in advance.
Old Nov 19, 2002 | 07:56 PM
Fuuma0083's Avatar
Default Re: SRS cluster is on? How do you turn it off? (Audio28)
If you "JUST" want the light to be off just take out your gauge cluster and take out the bulb for it. *The easy way out of it*
Old Nov 19, 2002 | 11:14 PM
T25 civic's Avatar
Default Re: SRS cluster is on? How do you turn it off? (Fuuma0083)
The best way to fix that would be to take the bulb out of the cluster. Now the right way would be to get the right year airbags. Should have done it right the first time!
the guy before you.
Nick
Old Nov 20, 2002 | 03:18 AM
Chiovnidca's Avatar
https://honda-tech.com/zerosearch
Old Nov 20, 2002 | 05:01 AM
EleanoR's Avatar
Default Re: SRS cluster is on? How do you turn it off? (Chiovnidca)
Should be a connector i believe on the back of your cluster that is yellow in color. Pull that out and the light should go off.
Old Nov 20, 2002 | 07:51 AM
DevinW's Avatar
Check out this link: https://honda-tech.com/zerothread?id=264288
It shows you how to properly reset the SRS light.
tofu1413
Jan 28, 2011 08:54 PM
WiedemannC
Honda Civic (2001 - 2005)
Oct 22, 2010 04:33 AM
peter96ek
Feb 15, 2008 01:52 AM
CeeJayy
Aug 25, 2007 09:06 PM
Dc2 Powered
Aug 1, 2004 02:33 AM
