SPRINGS OR COILOVERS?
Old Apr 20, 2004 | 08:20 PM
JDM ej1's Avatar
Default SPRINGS OR COILOVERS?
i want to get skunk2 or ground control coilovers for the adjustablity but they're kind expensive, or i could go with some neuspeed or h&r springs what is better?
also if i get springs what is the spring that drops the lowest i have a 95 coupe
Old Apr 20, 2004 | 08:25 PM
spaceman's Avatar
Default Re: SPRINGS OR COILOVERS? (JDM ej1)
skunk2 coilovers work for me
Old Apr 20, 2004 | 08:38 PM
Sliced Beard's Avatar
Default Re: SPRINGS OR COILOVERS? (spaceman)
i prefer coilovers
you are able to adjust the ride height at a moments notice and if you want to move up to a higher spring rate it is a lot cheaper than drop springs and you dont have to worry about a change in ride height when you buy new springs.
Old Apr 20, 2004 | 10:15 PM
blackeg's Avatar
Default Re: SPRINGS OR COILOVERS? (dirtyd463)
i bought springs, and wish i had coilovers. i would love the adjustability(cause my car sits higher on one side for some reason) and also good brand coilovers will have stiffer spring rates than my crappy arospeed springs
Old Apr 20, 2004 | 11:26 PM
rxse7n
Guest
Posts: n/a
Good springs seem to have a better ride from my experience. It is all a preference thing. If you get coilovers, you will most likely only change the height once after you install them. If you select the proper "drop" of a spring, than you would be happy too.
Old Apr 21, 2004 | 05:03 AM
JDM ej1's Avatar
thanks, ne more opinions
bigpunn421
Suspension & Brakes
11
Jan 22, 2012 11:03 AM
blk94gsr
Jan 23, 2006 08:12 PM
yotaplay
Sep 8, 2002 06:13 PM
DRxCIVIC
11
Apr 22, 2002 09:33 PM
preludeChaos
Oct 9, 2001 07:28 AM
